Order for Transistors in Big Muff
Started by Giglawyer, September 17, 2014, 10:46:45 PM
Giglawyer
I am building a Big Muff Pi, and was wondering:  in what order do you put the transistors?  Lowest to highest Hfe?  Highest to lowest?  Whatever sounds best?  I am using some 2n5133s that are between 350 and 450  Hfe.
Thanks.
Check out my builds - http://www.giglawyer.com
I don't think it makes a whole pile of difference, unless the hFE is particularly low.  Check out the discussion at Kit Rae's Big Muff site ("Is There Mojo in Vintage Components?" section).  Use sockets and audition them!
Elijah-Baley
Quote from: Giglawyer on September 17, 2014, 10:46:45 PM
I never built one, but I read often that is the good method.
