Powering multiple circuits in one enclosure
Started by joeychickenskin, November 14, 2014, 09:57:38 AM
joeychickenskin
Hi
I have a nice big enclosure and am looking to build an SHO running into a Fuzz Factory running into a Machine into it with a tonestack at the end and a voltage sag to the Fuzz Factory (with switches to switch in/out the tonestack and voltage sag).
Can I wire the three circuits to the same 9v power socket (+ve terminal) with grounds from all of the circuits going to the -ve terminal on the socket?
If I do take a wire from the +ve terminal on the socket through a pot for the voltage sag to the Fuzz Factory will it affect the SHO and Machine?
Apologies if this has been covered elsewhere, I tried a few different phrases to search for it.
antonis
If by +Ve and -Ve you mean the +9V and GND respectively, you shouldn't have any problem..
(as long as your 9V supply is capable to power all the circuits..)
joeychickenskin
Thank you, i imagined an elaborate three 9v input scenario run from a single daisychained power supply anyway and assumed that one input should be fine for all three.
JC
