Question for builders of G. Forrest Cook / Gaussmarkov Spring Reverb
Started by Strategy, November 28, 2014, 05:43:05 PM
Strategy
Pretty close to done with this. Question for those of you who have built it, does Reverb level control amount of reverb, or wet/dry blend?
Hoping I can get 100% wet mix (no dry signal) from this for using on the auxiliary send of a mixer
thanks,
Strategy
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
It only adjusts wet level, which is how most guitar amp reverb controls work.  If you want 100% wet, simply lift one end of R5.
Strategy
Mark: I was thinking to put a switch there in case that was how it worked. Thanks for confirming!
Strategy
