DC Jack Confusion
Started by MrKarter77, January 18, 2015, 09:53:31 PM
MrKarter77
Ok, im getting alot of confusion on this, i am by no means an expert here, but i have done my fair share of electronics, and even have a DIY 10w valve head.
However this is my first guitar pedal, a TS80 clone, im stuck on the DC jack.
From what i can see, following this guide
http://gaussmarkov.net/wordpress/thoughts/wiring-up-a-1590b/
that it uses a different kind of DC jack to what is available, the one i have switches on the outer lug, that earths on the chassis.
Knowing that, what is the best route here? source a panel jack that isnt metal, if so anyone know any australian suppliers?
armdnrdy
Quote from: MrKarter77 on January 18, 2015, 09:53:31 PM
Yes.
You are looking for a plastic (isolated) 2.1mm x 5.5mm panel jack.
Check with the suppliers in your area or....EBay Australia.
Buzz
#2
The link pictures a "no battery" power setup.
If that is what you are doing, you don't need a switched jack ( as pictured there )
Here is an Australian supplier for a non-switched DC jack.
http://www.diyguitarpedals.com.au/shop/index.php?main_page=index&cPath=15
They are smaller than the switched jacks. That's a bonus in a 1590a build.
He's got some pretty cool stuff on that site, check it out.
Edit:
Here is another AU supplier, this time with some switched jacks suitable for builds with a battery option:
http://pedalpartsaustralia.com/index.php?main_page=index&cPath=4_6
I am the Nightrider. I'm a fuel injected stompbox machine. I am the rocker, I am the roller, I am the MIDI-controller!
Paul, chromesphere, (www.diyguitarpedals above) is a good supplier even if you're on the other side of the planet.
Buzz
Quote from: davent on January 19, 2015, 09:33:47 PM
Absolutely. All top notch gear and a top bloke too.
SuzukiScottie
eBay Australia 10 for $1..45, free postage. Search for dc power outlet 5.5x2.1.
