can i power more than 1 of this circuit with the same power supply
Started by JohnForeman, March 08, 2015, 08:38:10 AM
JohnForeman
A non-pedal tech question:
I want to build 4 of these:
http://www.redcircuits.com/Page119.htm
to use as a home studio headphone monitoring system as was wondering if i could power them with the same power supple.  Since i know nothing about design and only build, i wanted to ask the pro's.  At first, i thought it should work but now i'm not so sure.
thanks
GGBB
Shouldn't be a problem as long as the power supply can deliver enough current for all 4 units. According to their specs, the max draw appears to be 17mA each, so 4 times that is 68mA. Give yourself some breathing room and go to at least 100mA.
JohnForeman
Quote from: GGBB on March 08, 2015, 10:15:07 AM
So i wont have a problem with cross talk between the amps?  Each one will have it's own mix coming from the mixer.
GGBB
I doubt it, but I'm not an expert. How you build it - specifically how you design the grounds and lay out the circuit - has an impact.
