Compressor with clean blend and loop
Started by Mr. Lime, December 26, 2014, 12:04:03 PM
Mr. Lime
I am planning to build myself a compressor with some mods.
It's basically a Ross Compressor but I want to add a clean blend with a loop.
With the loop I want to mix a distortion pedal to the clean compressed sound.
Someone has done something similar before in this thread: http://www.diystompboxes.com/smfforum/index.php?topic=40292.0
I would like to blend the clean signal with a different methode, just like roseblood11 did with his Rosescreamer using a single Op-amp.
The original output pot is 100k B, with the blend circuit it would be 10k, is this alright?
Would the new blend methode work?
Thanks a lot
best regards
Mr. Lime
Here's what I came up with:
I added beside the clean blend a loop for external effects in parallel.
There are two new switches too, a jangle switch and a "distortion" switch.
I can't say how the distorion will sound like, but I saw this mod some time ago and it seems to work.
Any suggestions how I could improve the distortion part?
