Need help making an alpha rotary work for the Tap tempo tremolo
Started by acehobojoe, March 12, 2015, 11:26:46 AM
acehobojoe
I have two rotarys, this larger 12 position one that I think will be pretty simple :
http://www.mammothelectronics.com/ALPHA-SR2611F-0112-18R0B-D8-N-ROTARY-1P2-12T-p/820-1p2-12t.htm
However the complicated one will be this one that I have :
http://smallbear-electronics.mybigcommerce.com/9mm-rotary-1p6t/
The first one seems very much like the diagram listed for the TAPLFO Chip,
however the smaller one seems a little harder to figure out .
http://www.electricdruid.net/datasheets/TAPLFO2Datasheet.pdf
anotherjim
The 6 throw common rotor contact is called "R" - it seems to have 2 terminals for that. It's only got 6 positions, you can use it but you would have to fit the entire resistor chain and simply select 2 choices you can't have  ;D.
The 12 way can be restricted to only allow 8 positions.
acehobojoe
:D I was hoping to use the first for the 8 pos thing and the second for the Division portion I think it's 6
anotherjim
By Division do you mean the Multiplier control?
... then you use the full resistor string and  wire the 6 throw #1 contact to the top of R4 and on thru to #6 wired to the top of R9. Ignore the top 2 connections as it says in the pdf "The top two options are not used for the Multiplier."
