Geofex bootrapped twin T question...
Started by LiLFX, August 21, 2015, 08:34:39 PM
LiLFX
Here is the schematic...
http://www.geofex.com/article_folders/eqs/twintee3.gif
If I wanted to use a bipolar power supply I'd omit the voltage divider and the 100K bias resistor on U1a, but what do I connect the end of the 50k pot to? Would I need to keep the voltage divider and apply the half supply voltage?
GibsonGM
I believe you would connect it to (signal..AC) ground, LilFX.   Right now it's "in the middle" of the signal's rise and fall (Vref), as it should be...if you use a bipolar supply, signal (AC) ground would be the same thing.
Ex: +9 and -9V supply.  0V is your "Vref" for all intents and purposes; 1/2 of power supply.  So, anywhere calling for "Vb" or "Vref" would go to 0V.
LiLFX
See..that's what I thought since your power supply is AC ground. I just wanted to make sure I wasn't smoking something.
