Fuzz Central's Vox Clyde McCoy wiring problems
Started by soupbone, January 01, 2014, 08:23:21 PM
soupbone
I've got all the parts for Fuzz Central's Vox "Clyde McCoy" Wah layout,and i'm a little stumped on some of the wiring.I'm going to be using the Standard Carling dpdt switch wiring scheme;http://geofex.com/FX_images/stompsw.gif   Here's the link to the Clyde;http://fuzzcentral.ssguitar.com/mccoy.php  Ok,on the layout we got; 1=Input (is this the "Effect Input"?) Next,We got Wah 2/3 (I'm guessing this is to the lugs of the pot?)Wah 1 (would be ground i think?) Next, 9v+ (obvious one),and the last are Grounds.Where is the "Effect Output"?I'm not seeing it on the board layout.Thanks in advance!
soupbone
Quote from: soupbone on January 01, 2014, 08:23:21 PM
I've got all the parts for Fuzz Central's Vox "Clyde McCoy" Wah layout,and i'm a little stumped on some of the wiring.I'm going to be using the Standard Carling dpdt switch wiring scheme;http://geofex.com/FX_images/stompsw.gif   Here's the link to the Clyde;http://fuzzcentral.ssguitar.com/mccoy.php  Ok,on the layout we got; 1=Input (is this the "Effect Input"?) Next,We got Wah 2/3 (I'm guessing this is to the lugs of the pot?)Wah 1 would be ground i think?) Next, 9v+ (obvious one),and the last are Grounds.Where is the "Effect Output"?I'm not seeing it on the board layout.Thanks in advance!
I just watched a YouTube video on how to make a Dunlop Crybaby True Bypass.The "Effect Out" is the Blue Wire that splits from the 1st Lug( the lug at the top of the pot,towards the switch.)The "Effect Input" wire is green.So,using this info the "Effect Out" would split from the pot and then going to the switch,and the "Effect Input" would go to the 1=Input.Does this sound correct?
soupbone
Quote from: soupbone on January 01, 2014, 09:29:09 PM
I forgot..The lug wiring is 3,2,1.(3 being the top).I think I figured it out. :icon_biggrin:
ORLANDO
I have a problem with the Vox Clyde McCoy Wah
I built the Vox Clyde McCoy but only works halfway.
Is it okay to put the cursor in parallel a trimmer or what to do? Thanks ORLANDO ITALY
