BIG MUFF PI not working
Started by jan007magic, September 08, 2015, 03:38:06 AM
jan007magic
hey guys, I built a Big Muff Pi (green russian) with Rams Head PCB layout, followed everything on the layout but it didn't work..
I used a 2N3904 instead of a 2N5088, all mylar caps except for the 470pf's which are ceramic.
the transistors did not get hot when I plugged it in.
thanks!
Elijah-Baley
When you get a "not working building" the problems are the usual.
You should search for some debugging methods.
Meanwhile, can you give us more details? Did you get any sounds? Are you testing just the circuit or are you connected the footswitch already?
First check: read the pinout of your transistors datasheet (2N3904s are ok) and compare with the any big muff npn schematic, and look your pcb.
jan007magic
input and output are directly connected
layout
schematic
build
GibsonGM
No dude, the input is where it says "SW 1a".  What you're seeing is the power switching - where your input jack switches the power on and off when you insert/remove it.  That part of the jack isn't connected to anything audio, so it's not part of the signal path.
On the first page of the build your own stompbox forum, there is a sticky post called DEBUGGING.   Read it, try to provide the info, and people will be able to tell you what to do.   Shooting in the dark is a waste of time, don't do it.   You probably need an AUDIO PROBE (search), which would tell you a LOT in a short time...
hymenoptera
oh my. How do you plan on getting those pots through their holes in the enclosure? They're pointing in 3 different directions!  :icon_surprised:
"Radio Shack has nothing for anyone who's serious about electronics." - Jeri Ellsworth
jan007magic
I know where to put the input and output and the power, I just didn't installed the  footswitch
