Did you guys see this? NEW at Mouser
Started by aron, September 16, 2014, 01:04:12 PM
You can always use the surface mount versions, they're not going anywhere. I've seen people selling adapter boards, maybe even already mounted adapter boards.
From Paul's site;
http://www.diyguitarpedals.com.au/shop/index.php?main_page=product_info&cPath=1&products_id=286
hymenoptera
I'm deff including some adapter boards when I order from Paul. I wouldn't mind stocking up really. Like 100 boards, and 50 x J201, and 50 x 5457, but I don't want to wipe him out of his stock of boards either!
"Radio Shack has nothing for anyone who's serious about electronics." - Jeri Ellsworth
Luke51411
Quote from: hymenoptera on September 07, 2015, 12:57:32 PM
There are a few adapter board shared layouts on oshpark as well. They are a little cheaper, maybe a couple cents which I wouldn't not order from Paul over a few cents but there is one layout that I like the footprint better as it is a bit smaller and closer to the same size as a through hole board.
hymenoptera
Quote from: Luke51411 on September 07, 2015, 05:03:41 PM
Ah I see! Perhaps then I should order some from both sources. Then all my bases are covered, and I can decide for myself what I should like to use.
Luke51411
The nice thing about Paul's is that the pins are labeled. One thing to be careful of is that once they are soldered you can't tell the difference between a 5457 and j201
hymenoptera
Are the pinouts universal for all SMD JFETs?
J0K3RX
#26
Quote from: hymenoptera on September 07, 2015, 07:13:51 PM
Most of the popular SMD JFETs that are used in pedals are "universal" but, I say that with great apprehension...  :P I would think the best rule of thumb would be to assume that they are not universal and be very happy later on down the road that you did not just solder 100 of them or more in circuit with the wrong pinout  :icon_wink:
On another note: Thought maybe some of you would be very pleased to know that you can now get a really hard to find jfet at your friendly mouser or digikey now!  :icon_wink:
4,196 In Stock - Can Ship Immediately
http://www.digikey.com/product-detail/en/2SK208-R(TE85L,F)/2SK208-R(TE85LF)CT-ND/4503201
2,281 In Stock - Can Ship Immediately
http://www.mouser.com/ProductDetail/Toshiba/2SK208-RTE85LF/?qs=sGAEpiMZZMv4z0HnGdrLjnwNZ9rg4nWl40oK3%2fTw9Rsiw81qNSYyVQ%3d%3d
Edit: Ok, still not getting it?
Hint:
Drain current/idss = 0.3 - 6.5 mA
Used in all of the AMT Legend series preamp pedals... :icon_neutral:
> Hint: Drain current/idss = 0.3 - 6.5 mA
The -R part is: 0.30 to 0.75 mA
Fine for small stuff.
J0K3RX
Quote from: PRR on September 09, 2015, 03:42:48 PM
Good catch Paul! Shoulda known better than to try and slip one by you :icon_wink:
If you are building amplifiers with ~~50K drain resistors, 4.5V/50K is 0.1mA, so a 0.3mA-0.75mA part like this -R sort will do the job.
Switching and heavy buffering applications may want a fatter FET.
J0K3RX
Those are the primary jfets used in all of the AMT Legend series 1 and 2 preamp pedals and the in the preamp section of the AMT Stonehead 50 amp..
tacobender
So what's the mojo with these particular fets? I don't know much about jfets, was there a popular design these were used in?
hymenoptera
I don't think there's any mojo to it. It's all about the curves. These (5457, j201, mpf102...) are all real sensitive devices, so they respond well to small signals with much biasing. Their curves are about right for guitar pedals.
