4 step sequencer with timer per step on stripboard
Started by EATyourGuitar, October 25, 2011, 12:50:40 PM
EATyourGuitar
originally drawn on paper in this thread at muffwiggler forum. I know this is more for synth nerds but you can apply it to any vanishing point style pedal.
this layout is has not been tested yet. the 4 100k resistors and the voltage follower has been left out but you can add that on another board. or just use a passive mixer with a buffered multiple after it.
I'm using the $0.71 stripboard from tayda
19 high x 34 wide. the cut corners are for the mounting holes where there is no copper on the board. they come like that.
I did not have time to check the datasheet of each IC so I dont know if its really good to run it at +12V or +15V. you can probably get pretty close to audio rates or at least a 4 step LFO. you could also use this as a gate sequencer hooked up to 4 envelopes or drums. watch out for the strip on the 4066 that connects pin 4 and 11. there is not cut there. that is how it is.
8)
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
notnews32
Hey...  this design sounds great! Did you have any luck verifying this drawing? I'd love something like this.
