Popping when I turn my Fuzzface "ON"
Started by chuckfalcon, January 07, 2016, 09:56:54 PM
chuckfalcon
Hi everyone, I have been working on a pretty standard Univox Superfuzz circuit.  It works but there are a couple of issues.  It makes a "pop" sound ONLY when I turn on the fuzz.
Here are some things to note:
-I am using a 3PDT
-I'm not using an LED
-I put a 1M resistor from the input to ground
-I put a 1M resistor from the output to ground
-I am not getting any DC reading from tip to ring on the input OR the output except for 0.001V (but that wouldn't really matter though, with a reading that small, right?)
I was getting a pop sound when I hit the bypass switch to turn the fuzz on AND off.  I looked at my wiring and my output cap's orientation was reversed.  So I swapped it.  No more popping when I hit the bypass switch to turn the effect off
Anyone know how to cure my popping when I turn ON my fuzz?
Also one other thing that I noticed.  When I power this circuit with a 1-spot and turn on the fuzz, I am hearing a high pitch humming sound.  When I power it with a 9V battery, it goes away.  What in the world could THAT be?
Any help?
peterg
Please post the schematic and layout you used.
chuckfalcon
#2
Okie doke.  Here is the layout:
Here's the schematic.  All I did was add the 1M's to the input and output:
chuckfalcon
One other thing that I noticed is that I can only hear the "pop" when the "gain/expander" and the "volume/balance" are turned up at least halfway.  What could this mean?
antonis
#4
You shouldn't use the 1M output resistor (it's purpose is covered by the 100k one..)
You should rename the -9V green trace on your layout as GND..  :icon_wink:
Maybe you have to try a 3PDT IN & OUT grounding wiring (despite of the bleed resistors)..
edit: I can't verify capacitors matching polarity on your layout..
antonis
 :icon_frown:
Quote from: chuckfalcon on January 07, 2016, 09:56:54 PM
If you multiply the 1mV on the Input with the overall circuit's gain, I'm not so sure if it remains small enough...
chuckfalcon
#6
Quote from: antonis on January 08, 2016, 07:24:26 AM
Quote from: antonis on January 08, 2016, 07:24:26 AMMaybe you have to try a 3PDT IN & OUT grounding wiring (despite of the bleed resistors)..
Here is how I have the 3PDT wired.  I think that this grounds the input but not the output.  Could that maybe my problem?  Also, I am not using an LED and I don't have anything at all connected to the "LED LUG.
Whoops, sorry bout that.  I edited it and made them a little larger and not transparent.  I hope that helps.
Thanks for your help.  This thing is driving me crazy.
