First SMD board
Started by acehobojoe, December 17, 2015, 03:21:47 PM
acehobojoe
http://i.imgur.com/Rgwhe8I.jpg
This is my first attempt at an all surface mount board. I used 0603 components. :p
It is a boost that is basically half of the design from the "peppermill" circuit at runoffgroove.
It has a tone modification that boost the high end with a switch engaged.
So far, it has correct voltages. Hope it works when put in the enclosure.
G. Hoffman
Use 0805's for ease of seeing, and space them closer - tiny boards are the whole point behind SMD!!!!
But looks good.
Gabriel
acehobojoe
I'll eventually try to make it fit behind a pot :)
Are there any extra procedures I need to be mindful of?
