dam logan layout for the mk1 tonebender?
Started by strassercaster, November 29, 2015, 03:03:53 PM
strassercaster
hello i have some issues building the mk1 tonebender. does anyone have the DAM logan layout they could share with me. i was told it is much better and its no longer posted at the other sires.Thanks I would really appreciate it
Electric Warrior
not the layout you're talking about, but this one, based on the original vero layout, works:
Don't forget to cut a trace under the 2M2.
This uses a slightly different schematic than the one you were working with, but it's easy enough to adapt.
LightSoundGeometry
#2
Quote from: Electric Warrior on November 29, 2015, 03:36:32 PM
EW, I might be high but I cant see a trace cut under 2m2  ? I have worked my way to following flow and creating my own vero layouts. I have found a lot of layouts from various websites either dont work or have bugs in them.  I enjoy the challenge of laying out my own boards now. when I feel like not doing my own now, I use PCB boards from a places like tonepad.
I think you need leaky trannies , thats the secret you are hinting at in a subtle way I had just noticed in a lot of your posts. I have to thank a very kind dude for this revelation who shall remain anonymous.
Electric Warrior
Quote from: LightSoundGeometry on November 29, 2015, 09:39:08 PM
There was no space between the resistor and the wire to put it, but it's obvious that it needs to be there. :)
But you're right, it may be misinterpreted. And I ended up doing it like this:
Leaky trannies sure aren't wrong here. The first MKIs probably had three OC75s, so that's what I used for my build - and it worked for me. Not sure how much leakage it really needs, though.
LightSoundGeometry
Quote from: Electric Warrior on November 29, 2015, 10:45:40 PM
well, I can finally stop worrying about making a TB and concentrating on practicing and jamming along with Led Zep  ;D
