dual amp DI box with individual mute toggle switches
Started by FaithElectronix, January 14, 2016, 11:33:10 PM
mth5044
FaithElectronix
ok, what if I had an input for each switch? an individual In and out for each switch, (amp)?????? In that form of diagram, drawings will work.
S.K. Latham
potul
I don't get your point about 2 inputs...How many guitars are you wanting to play?
The diagram that mth posted is assuming you have:
-1 Guitar (that will be connected to the INPUT of the box)
-2 Amps (2 OUTPUTS in the box, connected to 2 AMP inputs)
You can then select if you want to use AMP A, AMP B or both.
If what you want is 2 different guitars in 2 different amps, then you need something different.
FaithElectronix
To run my pedal board effects in stereo 2 cables. One for one amp. And one for the other. With this switch to mute a specific amp for certain songs.
S.K. Latham
mth5044
Quote from: PRR on January 15, 2016, 12:48:00 PM
So two mute switches in one box.
I believe he wants to be able to run the amps together as well?
One stereo input, two mono outputs that can be run A/B+AB.
OP - Isn't this exactly what your last thread was about?
Un-mute both amps.
It is REALLY hard to talk about this without a picture.
FaithElectronix
yes two separate mute switches in one box. My tremolo when hooked up in stereo with 2 wires coming out, has a rotary sound that's really cool. When running cables from the pedal: one going to one amp and the other cable to the other amp. Thats why I wanted the 2 inputs/ 2 outs. And yes I want to use both amps. but have the toggle switches to mute Either A or B amp. Making more sense? It's crazy, but I want to still have that crazy sound I can get from my tremolo, When playing both amps on. Just need to know how to wire those switches like that.
Pictures are in the 3 links in the first post.
S.K. Latham
FaithElectronix
2 stereo jacks/ 2 mono jacks and 2 DPDT toggle on/off switches. Can you make a diagram for me on how to wire those up for the way I'm wanting to use the box?
S.K. Latham
FaithElectronix
Quote from: FaithElectronix on January 15, 2016, 01:51:46 PM
or would that be an A/b/x/y switch?
S.K. Latham
idy
What was wrong with the picture I gave you, two seperate mutes. Either/or/and/not you put up is too complicated. It has one switch that chooses A or B and a second that chooses both/one amp(s).
Just use two mute buttons. Each one grounds the input of the unused amp.
Here it is again:
http://www.aronnelson.com/gallery/main.php/v/diyuser/kill+switch.jpeg.html
You make two of these.
idy
You don't need to call this a "DI Box" unless you need one of those. An impedence matcher. You don't.
FaithElectronix
sorry haven't been on. I have made it and it works fine. How could I add a jack for my EV-5 expression can control the volume?
S.K. Latham
