Help me understand Bridged-T RC Filters
Started by edvard, August 04, 2010, 11:34:57 AM
The capacitor ratio determines the depth of the notch.
In this circuit the Q (which defines the bandwidth of the notch) and the notch depth are related.  You can't change one without changing the other.
garybdmd
Hi there,
I've spent several days trying to figure out this bridged T circuit and the basic
formulas someone would need.  I made/derived a formula for Q and bandwidth
which are estimates only, but quick and easy.  Here is a summary of everything
I found.  The Q formula and bandwidth formulas I came up with and if you'd like
to see how I did it you can check out what I did.
https://sites.google.com/site/garydavenportelectronics/home/bridgedtnotchfilter
     -------C1-----
in --|            |--- out
     --R1------R2--
          C2
                        1
center frequency = ------------------
                   2pisqrt(R1R2C1C2)
                   1 + R2/R1
notch depth= --------------------
               1 + R2/R1 + C2/C1
                        1          1
bandwidth estimate = -------  -  -------
                    2piR2C1      2piR1C2
                 sqrt(c2/c1)
Q estimate =   -------------
                (c2/c1)-1
db loss at center freq = 10 log (notch depth)
I would appreciate any critiques/suggestions about this because its quite complicated.
