Can you guys confirm my wiring
Started by Bobandy, February 15, 2016, 05:38:42 PM
Bobandy
I am building a circuit that will be a boost/fuzz and am wondering if my wiring is correct. There will be 2 fuzz circuits wired to dpdt toggles that can be used individually or simultaneously. If both are off it will just be a boost. I am also wiring a footswitch to activate a feedback loop and am including a momentary stutter/kill footswitch. Assuming my power and ground connections are good, can you tell me if my wiring works? I apologize for the crappy drawing but couldn't figure out a way to explain how it was being wired.
http://www.aronnelson.com/gallery/main.php/v/Schematics-etc/20160215_150319.jpg.html
GGBB
Looks fine. The feedback will only work when the second fuzz is on - was that intended? Otherwise it will probably add some kind of noise from the disconnected fuzz or possibly mute the signal depending on how you are wiring the switches.
Bobandy
Yea that was the idea I just wasn't sure if the feedback switch would work like that.  Originally I had planned to bypass the signal through the feedback switch but this way seems a bit easier and less likely to have issues. Thanks
