Adding jumper to 3PDT to ground board
Started by Ben Lyman, February 11, 2016, 05:11:03 PM
Ben Lyman
The first pic is how I have been wiring up my 3PDT. If I want to go back and quickly ground all the board inputs of my pedals, is it okay to simply add a jumper? The second pic shows what I have in mind with the red line indicating the jumper wire.
        -S. Vai
mcknib
Yes that'd ground the board input in bypass mode no probs
Same as mine apart from using different lugs mine being a jumper from 1 to 6
Ben Lyman
Thanks Billy! hmmm... Does this mean I don't need a 1M pulldown resistor anymore?
        -S. Vai
peterg
Quote from: Ben Lyman on February 11, 2016, 09:13:57 PM
You still need the pulldown resistor.
Ben Lyman
#5
Quote from: garcho on February 11, 2016, 10:35:36 PM
Thanks Garcho! very helpful  ;)
Quote from: peterg on February 11, 2016, 10:55:05 PM
Okay, thanks. I will keep adding them to my builds. But why won't the input cap drain out with a direct contact to ground? Or does the pulldown res also have something  to do with input impedance when the effect is engaged?
Here's an interesting read:
http://www.mrblackpedals.com/blogs/straight-jive/6629778-what-really-causes-switch-pop
        -S. Vai
