Pin voltages for Ibanez CS-9?
Started by diablochris6, March 07, 2016, 04:36:07 PM
diablochris6
Does anybody have the pin voltages for the Ibanez CS-9 chrous ICs and transistors? I have a modified version (no stereo out) on my breadboard (I couldn't find room for the noise gate section though) that I am getting some sound out of. The audio signal is quite faint, and there is a low noise that overpowers the audio signal. I have isolated the issue to be somewhere between the output of the 3207 and the output of the circuit. Any readings would be greatly appreciated as I recheck my breadboard components and placement.
Scruffie
Did you leave the FET in without the gate? That'd cut your level.
diablochris6
No, I removed the FET altogether.
The FET probably needs to become a short drain-source. i.e. if you "remove" it, you want a jumper or a 100 ohm resistor. I don't know the circuit though.
armdnrdy
Quote from: diablochris6 on March 07, 2016, 04:36:07 PM
The area you have "isolated" is approximately half of the signal path.
Barring the unlikely event of someone popping in with voltages for this chorus...
I would audio probe the circuit to pinpoint where the signal gets "lost"
Posting the schematic with your voltages might get you more help as well.  ;)
diablochris6
Well, going over my breadboard again...I found the issue! I placed a resistor in the wrong spot; it's the dumb mistakes that bite you in the butt sometimes. It works just fine now. The wet signal seems to overpower the dry, but I figure the noise gate/FET section of the CS9 might help a little with that. Thanks for the suggestions everybody.
