Can anyone help me with adding a switch to a Meathead tagboard?...
Started by PorkyPrimeCut, March 21, 2016, 04:56:03 PM
PorkyPrimeCut
I've seen some discussion on switchable caps & was thinking about doing something like this with a couple of my upcoming builds.
I'm planning on making 5 - 6 tagboard Meatheads in black with snazzy knobs & dial plates. I know they sound great and figured the premium extras might make them that little bit more attractive to buyers. The tagboard will be like my Buzzaround build, carbon comp resistors & tasty axial capacitors. The build is the antithesis of the Buzzaround though as it's a very less is more kind of thing.
So, what options are out there, caps-wise. I read one idea that changed it from a "standard" to a "dark" version. Any others?
Also, can anyone either point me in the direction of a tagboard diagram that has an added switch or, ideally, point out where the switch/cap combo would go on this tagboard layout?....
I know there are veroboard diagrams with what I want but I can't translate them into tagboard versions.
blackieNYC
Attach another cap to where your 10nf meets the base of Q1.  Attach a .47 (?) uF cap there. The input wire now goes to the center of a single pole double throw switch. The unattached ends of the caps go to the two outer lugs of the switch.
PorkyPrimeCut
Thanks for the reply!
So, like this....
Seems pretty straightforward :)
it will pop each time you throw the switch, unless you add equalise/pulldown resistors, I think across the two outer switch lugs, and then from one outer lug to ground.
" I will say no more "
PorkyPrimeCut
