2n2646 in hummingbird clone
Started by cnspedalbuilder, June 13, 2016, 01:58:55 AM
theehman
Quote from: cnspedalbuilder on June 18, 2016, 11:05:26 AM
Also, I know the 2n2646 is a prime suspect, but I found that the sound and tone remain even if I pull out the transistor altogether. Does that make sense in this circuit or does it mean I have a hidden short lurking somewhere?
Yes, it will still work with the UJT removed   The signal doesn't go through it.
Ron Neely II
fx schematics and repairs
cnspedalbuilder
Thanks Ron, you rock! I just want to make sure that the rest of the circuit is solid when your 2646 arrives.  :D
