Can I replace a 3pdt footswitch with a on off toggle switch
Started by Belanger, April 24, 2016, 01:52:21 PM
Belanger
So long as I'm willing to drop the LED this is possible with a on off toggle correct?  Also would i wire it the same?
The best substitute for intelligence is silence
karbomusic
You don't have to drop the LED if you use a 3PDT toggle. You don't have to drop the LED with a DPDT if you use something like a millennium bypass or similar. Otherwise, you could get by with a DPDT/No LED for a standard true bypass type circuit.
Ben Lyman
It performs the exact same function, so you can just wire it up the same if that's easiest for you.
        -S. Vai
Belanger
Thanks so much for the help guys.  Can anyone explain the millennium bypass to me. I keep hearing about it but I'm %100 ignorant to what it is and how it works to be honest   I do have some schematics for a daughter board version
Jdansti
when you say "on off toggle", what exactly do you mean? single throw? how many poles? etc?
"Did I say that?"
"I'm not playing cards."
all tariffs now subject to a disrespect surcharge of 32%.
Kennt82
I made this dual fuzz.  The switch in the middle is to change the effect order, but the two on/off ones are wired the same as a stomp.
Jdansti
Quote from: Kennt82 on April 26, 2016, 01:18:17 AM
Re: Can I replace a 3pdt footswitch with a on off toggle switch
We now have living proof that not only can it be done, but it can be done twice in the same pedal!  :D
Kennt - a question for you - when you say
Quotethe two on/off ones
what type of switches are they? how many poles, etc?
"Did I say that?"
Kennt82
DPDT is fine if you don't need an LED.  3PDT will give you the extra row that you can hook up as you normally would. This is one way, with grounded input.  Even if you don't use an LED you may prefer that? Toggle or footswitch will be treated the same.
I also built a Fix'd Fuzz with DPDT toggles for each of the 4 stages and a regular stomp overall.
Belanger
Yah sorry I didn't even see the new posts until now. And yes dpdt is what I was referring to. Have to keep in mind you guys aren't mind readers and only have the info I provide. Which I do s pretty piss poor job of explaining you guys are amazing thanks for all the help on this one
