Need help for increasing treble tone of Angry charlie v3 clone
Started by ali1111, May 18, 2023, 04:36:52 PM
ali1111
Hi friends
I've  made a clone of Angry charlie V3, its sounds amazing and have a nice and warm  distortion but i think it has less treble, what is your recommendations for increasing about 30-40% treble to tone of this pedal
https://www.pedalpcb.com/docs/AngryCharles.pdf
There's a couple of caps in that circuit with are limiting treble above 1.6KHz - that's fairly severe, although it's only a -6dB/oct roll-off.
The first is C7/100p. You could reduce that to 47p or 22p, to gain an extra octave (or two for 22p).
The second is C17/22n. You could reduce that to 10n or 4n7, again to get an extra octave or two.
Those two are where I'd start, anyway. There's plenty of "harsh treble" roll-off in that design, but one person's harsh treble is another's "presence", so try putting some of it back and see how you get on with it.
One other thing to note: Although the *frequency* effect of the two caps is the same, one is before the clipping diodes and the other is after, so they won't both have the same effect on the sound. You might find you like one very open, but the other much more closed, and that could be either way around. Just be sure to test it both ways.
HTH
antonis
off-topic, but..
I don't like C10 placement..
(at least, not without a 100R or so resistor - in the cost of IC2,2 output impedance..)
ali1111
What about c19  (22n) cap in treble tone stack?
Do you think Decreasing it is beneficial or not?
Dormammu
Quote from: ali1111 on May 19, 2023, 01:56:07 PM
It is 2,2 nF, not 22.   According to the diagram.
I would suggest increasing it a bit. 2-3 times.
And of course, reduce C17 to 1nF.
antonis
C19 is 2.2nF, if I'm right.. :icon_wink:
https://www.petervis.com/record_players_and_turntables/baxandall-tone-control/circuit-and-calculator.html
or better, use the following..
Further reading:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/6/1980-NSC-Audio-_2600_-Radio-Handbook-_2D00_-Part-1.pdf
pages 2-46 to 2-55
P.S.
Highs already attenuated upstream can't be recovered by altering C19 so make sure that LPFs corner frequencies already mentioned by ElectricDruid are above your highs taste.. :icon_wink:
ali1111
Quote from: Dormammu on May 19, 2023, 04:08:15 PM
Sorry, i was meant 2.2nf
Box_Stuffer
Dormammu
Quote from: Box_Stuffer on May 19, 2023, 09:17:23 PM
You could turn up the treble on your amp....   8)
Or turn down the bass and mids. Even on the box itself.  ;D
antonis
To do what on a signal of already severely attenuated treble..??
Dormammu
Quote from: antonis on May 20, 2023, 10:30:21 AM
And where is the "severely attenuated treble"?
Are you saying that by throwing C19 into hell, we will not get any difference in the final signal?    :o :o
RC-filters don't work anymore?
eh la bas ma
I built the Angry Charles and I was also desappointed with the EQ.
Building the Captain Crunch Deluxe (MI Audio Super Crunch Box) solved the issue. EQ is much more effective on this build, and it's really easier to find some good settings.
I think Angry Charlie is a clone of the first version of MI Audio Crunch Box, with 3-bands EQ instead of a Tone control. The second Crunch Box version has its own 3-bands EQ and it's much better, in my experience. Probably the best MIAB circuit ever made. JHS's clone was interesting before MI Audio made the second version of their Crunch Box, I guess.
https://www.pedalpcb.com/product/crunchcaptaindeluxe/
I'd suggest to  build the Captain Crunch Deluxe, and give your Angry Charles to a friend, you won't need it anymore.
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
antonis
Dormammu
Quote from: eh la bas ma on May 20, 2023, 12:22:30 PM
Very strange statements.
I think you didn't appreciate active EQ because of your young age. (and lack of experience)
Passive EQs sounds flat for my taste, while active EQs provide some interesting possibilities.
eh la bas ma
Quote from: Dormammu on May 20, 2023, 01:09:56 PM
Is it ? Reading the MI Audio's manual :
"a fully active 3 band EQ for surgical tonal precision"
https://miaudio.com/wp-content/uploads/2017/03/SCBv.2-Manual-2.pdf
They both have active EQ.
Despite my lack of experience and my young age, the Super Crunch box's 3-bands EQ has much more range than the JHS's clone.
If you are missing some highs on your build, you should probably try the original circuit.
Dormammu
Quote from: eh la bas ma on May 20, 2023, 03:19:51 PM
Google search turned up not exact diagrams.
Ok, active — so active.   ;)
ClemTb25
Hello,
I implemented this on a JHS sweet tea. If you really swap the C17 capacitor, I would recommend to do a few tries, and to make a rather small change like 10-12 nF if you want more bite for high-gain tones.
In my case I added a switch that allows to select C17 to be either 22nF (stock) or 6nF (bright).
This is very useful at low gain; at mid/high gain (from roughly 10-11 oclock) it starts to be harsh, and you need to tame it using the treble knob.
With my setup, if I engage this 'bright' switch for high-gain tones, it basically reduces the useful range of the treble tone to 1/3, so I use it only to turn the Angry Charlie into an overdrive.
