Problem with wiring diagram
Started by royzbluz, December 19, 2016, 09:30:54 PM
royzbluz
This is what the instructions show.
This is the board I got and it does not have  the s lug that the top picture has. The 3pdt pcb has an s lug. What does the lug labeled s do and?
chuckd666
Read the description on the PCB daughterboard page - http://www.3pdt.com/products/3pdt-footswitch-wiring-board
QuoteS goes to the main PCB on our effect kits to connect the main PCB LED and resistor with the 3pdt switch. Alternativly you can use the 3pdt PCB onboard LED and a currenct limiting resistor.
Where is your LED indicator? On the main board or the daughterboard? Connect S - S together if you're using the LED mounted on the main board.
royzbluz
So if I'm using the daughter board mount I just omit the s?
chuckd666
Yes, if you're using the LED on the footswitch daughterboard.
