damage to bass amp head?
Started by Dimitree, December 20, 2016, 10:30:07 AM
Vitrolin
to what is your audio probe connected?
do you have an 10:1 oscilloscope probe?
if yes, there is no need for a voltage devider, as it is allready in you probe.
if not what are you using?
Dimitree
Quote from: Vitrolin on February 02, 2017, 03:28:23 PM
to the input of another amplifier,
it sounds fine when I audio probe on R1, so I can't explain how it could be a preamp problem.. But if I disconnect the preamp, the buzz is gone
my cheap oscilloscope doesn't have that, so I need an external voltage divider, as I said I did that test and rails looks quite fine
Sigh.
This isn't going anywhere.
Dimitree
Sorry, I didn't have my solder iron with me so I couldn't remove the output transistors, in the meanwhile I was trying to measure what I could
