TDA 2050 amp photo's & mp3
Started by MartyMart, May 04, 2007, 11:53:48 AM
tasos
Quote from: Victor on May 04, 2007, 01:05:02 PM
TDA2050 can suck a lot current, I burned a 2040 a year ago using a 15V@500mA ps .....  :-\
what?why is that? ???
Magnus
#41
Hello,
I'm going to build this power-amp and I have a question:
Is this schematic from page 1 ok or should I change something?
http://www.pbase.com/image/78436347/original.jpg
And the ground: Does the (pedal) preamp-ground have to be connected to the poweramp-ground?
Greetings
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
J0K3RX
Quote from: Magnus on February 28, 2017, 03:47:20 PM
Hello,
Greetings
Magnus
As for the ground question.. Yes, the cable you use to connect them together..  > preamp output to power amp input > That should do it. :icon_wink:
If you're gonna put both the preamp and the power amp in the same box then yeah, connect the grounds..
The schematic from the first page should be fine. It's the single supply configuration taken directly from the data sheet with a couple mods as he notes at the bottom of the pic.
Look at the data sheet and go to pages 6 and 7. Page 7 should help you if you need or want to make any changes... There is a board layout on page 6 also but, you may want to modify it or make your own unless you have some big 1000u electrolytic axials you need to find a home for..
http://www.edutek.ltd.uk/Binaries/Datasheets/Linear/TDA2050.pdf
cab42
I have built a couple of poweramps from that schematic without any problems (even copying Marty's vero layout from the photos).
Works perfectly and sounds great.
Remember a heatsink on TDA2050. It gets hot!
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
