tonepad Sinamp Volume issue
Started by maiko, March 13, 2017, 04:18:02 AM
maiko
so ive built the sansamp gt2 from tonepad and actually this is the 2nd one
This time im planning to use it as a preamp for my ggg TDA20x0
Question it is a very loud pedal i hardly past 8oclock on the volume and its already too loud.
any suggestion on how to lower the output.   it has a 5088 just before outpud.  can i adjust it there
any help would be appreciated.
https://imgv2-2-f.scribdassets.com/img/document/194292535/original/3894fea7ec/1487265476
try swapping the "vol" pot B100k with a log pot A100k. that might help shift the too loud point higher.
" I will say no more "
maiko
Yup ive tried this it actually helped alot and it placed my useable point to halfway but beyond
that its loud!! hahaha
antonis
Place a resistor in series with pot's upper lug..
maiko
you mean across lugs 1 and 2
so your suggesting i lower the pot value?    by half? so if 100k i solder also a 100k across 1 and 2?
not across, in-line with. try half the value of the pot, in series with the hot lug, so full volume will now be 33% lower.
really, you put a knob on that control, what difference does it make where you turn it to for comfortable listening levels?
maiko
ok i try to solder a 50k in series to lug 2
antonis
#7
Hot lug!!! - Upper lug!!! - Lug No 3!!! - The one that has the higher voltage!!!  :icon_cool:
Lug 2 goes to Op-Amp non-inerting input and the addition of 50k resistor will low down the GAIN of the NFB loop..  :icon_wink:
(and also the HPF cut-off frequency..)
maiko
