totally acoustic stompbox with bass/snare sounds??? (ie no amp/plugs)
Started by mixedup, March 24, 2017, 10:54:55 PM
mixedup
Any pointers/ideas/product link re how to get a totally acoustic stompbox type setup?    That is:
- no plugs/leads/amps
- produces a bass and snare type sounds
- for non-professional use, so just with friends at parties
- ideally with one foot device that would do both sounds (e.g. heel=bass, toes=snare sound), but else two feet/pedal devices
idiot savant
mixedup
so where do you put them in relation to your feet?  :icon_biggrin:
idiot savant
Quote from: mixedup on March 24, 2017, 11:03:13 PM
between them?
Actually I've seen people rig them up using kick drum pedals. You could also go bucket drummer style. Plastic suitcase + kick pedal = bass drum. 5 gallon bucket filled with gravel + kick pedal = snare.
mixedup
thats the type of thing I'm looking for - had been trying to see if someone has already gone through the design/test/refine and I can just order it...haven't seen anything yet...  Not sure if you can get one pedal also that would have both a heel and toe output, but then it would be how to get these with their respective tappers (whatever the ends are called) so they'd hit the bass and snare part of a Cajón
idiot savant
I don't know of anything ready made.
The guy I saw had a cut up and welded together double kick pedal, with a soft beater for bass, and a plastic beater for snare.
Another idea would be to rig up a %^&*tail kit. The snare and bass portions are in the same drum. Again, it'd have to be DIY'd.
idiot savant
mixedup
:)   thanks - will be interesting to see if someone tried/done this and if they could post any pics
idiot savant
Quote from: mixedup on March 24, 2017, 11:31:03 PM
I wouldn't be surprised if someone over on drumforum.org had rigged up something like that. There's lotsa cool busking setups people use.
If it makes a sound when you hit it, some drummer somewhere has it attached to a kit. :icon_lol:
(cue drummer jokes)
J0K3RX
mixedup
perfect!  oh.. price is a little towards professional as opposed to just for fun... if there were a simpler (just needs bass/snare/high hat) less expensive version of this that would be great?
