t.c. electronic dual parametric e.q. no power
Started by BDuguay, June 15, 2017, 10:39:37 AM
BDuguay
There's a diode that has gone open probably from having too much power applied. There's no legible markings left to determine what it was but there's a 1N4xxx present on the circuit too. The diode in question is orange and I'm thinking it's a zener but not sure of the specs. Does anyone have anything to add please?
Thanks,
B.
Fender3D
If you're talking about TC's dual param. pedal, it has only 2 diodes 1x 1N4001 and 1x 1N4148
If you're talking about TC's dual param. rack unit it has BZX79-C15 15V zeners after 1N4001 bridge diodes.
BDuguay
The pedal is what I have. So, that's a 1N4148 right next to the 1N4001?
Thanks F3D!
antonis
Replacing a blown open signal diode doesn't usually fix the problem..  :icon_cool:
Fender3D
#4
more precisely:
the 4148 stops DC from going into 9V battery and 4001 is polarity reverse protection.
If only 4148 is blown, the pedal should work the same.
Check the 4001 also...
BDuguay
