Consolidating power supply sections for multi-FX?
Started by tatou, July 16, 2017, 11:32:24 PM
tatou
I'm working on a 2-in-1 pedal design that combines a modded Gainster-like overdrive with a modded Rat-like distortion.
If possible, I'd like to simplify/reduce the parts count by consolidating the two power sections. They are essentially the same, but with a few value changes (+1 resistor):
Since I'm still a relative n00b, I'm not sure what effect changing these values would have on either circuit. So I ask:
1. How would you recommend consolidating these two into a shared power section, and
2. Why? (That is, what effect are the final/chosen values expected to have on each sub-circuit?)
Thanks!!
Longtime musician, effect-building n00b. Data dude at Duolingo and founder of FAWM.ORG.
tatou
Can someone explain a bit about the function of these components? Here's the suggested circuit from @PRR:
Here are my specific questions:
  • R21+R22 split the power voltage from 9V to 4.5V. Is there some reason to us 10k, or does the value particularly matter?
  • C22 is, I think, a filter cap to reduce AC hum from the power supply. What about C21?
  • The 47R resistor seems like it has little to no effect, what purpose does is serve?
the 47R works against C22 (and C20), providing an R//C filter for EVERYTHING connecting to "VC". R21//R22 allow a larger current flow as 10k's than as 100k's, and so the V/2 they produce is harder to "shift" with your loads. and then C21 provides a low impedance route to ground for EVERYTHING connecting to "VB", much less than the R21 does. this means less noise on your referenced inputs.
" I will say no more "
