Fuzz Face Bias
Started by thehave, August 31, 2017, 01:42:23 PM
thehave
Hey!
Beginner here and I just built my first pedal. I used Ge AC127 transistors using the schematic in the picture. The sound is pretty rough when the fuzz pot is turned all the way.
I want to put a 10k bias in the place of the 8.2k so I can alter the voltage at the Q2 collector. BUT how do I connect the bias to my pcb? Wire from terminal 1 to the collector and from 2&3 to the top row?
Thank you in advance. And sorry for the noob question.
-nik
italianguy63
Plexi
As italian guy says  :)
I personally prefers to use 5k pot and 4k7 resistor in series.
The range of 4k7 to almost 10 is the most usefull to my taste.
And please: use sockets with that Ge's!!!  ;D
To you, buffered bypass sucks tone.
To me, it sucks my balls.
thehave
Yes! It works!! Sooo much better now that I have one more variable to change.
And yes I used the sockets for the transistors ;D
Thank you!
