Doubt about article on old module Pluck Follower
Started by sergiomr706, April 23, 2018, 07:27:09 AM
sergiomr706
Excuse my nerdiness, but I want to add this to a 2399 delay I have,
http://hammer.ampage.org/files/Device1-11.PDF
and well, on page 7, where it says IC2 should be a BIFET op amp, or other op amp with very high input impedance, I d like to hear some suggestions about a useful ic
Thanks a lot
What they are really trying to say is using a JFET input opamp has a low input bias current, so the input bias current won't discharge the cap.   Pretty much any JFET/MOSFET/CMOS input opamp will work.
Actually, I'd have to calculate out how much of a difference that really makes since both IC's  have 1M resistors on the input.  You might get a small DC offset, probably not a big deal.
tonyharker
You probably wont find anything better than a CA3140 or a CA3130  BiMOSFET input op amps.
sergiomr706
What's the application for the envelope detector and larger
In your pt2339 design.
Lm358 l.p. amps  work well in some cases.
sergiomr706
Mt idea is very simple I want it to start hearing ir delaying the notes when I stop playing not having delay if i play a lot of notes.so after using a first envelope extractor, I think that basically I need pick final control voltage output to interact with the pot labelled dry /effects or blend .it's just a deep Blue delay clone
In Anderton's day, opamp inputs often sucked. The TL072 series is *the* obvious choice today. I'd even use it at IC1: the '741 is old and now costly, the '072 is real cheap. Don't worry that you need two '072 to cover three opamps- they are cheap enough to squander.
Have you considered a tails mod.
Im sure it could be done (to a point) with and envelope detectror.
If you use a vactrols ldr as part of a voltage divider (Which is essentially what the mix pot is) to cut off the delayed signal.
However it gets tricky when trying to get within a short time frame. Ie enough time to hear the first repeat if your playing a lively piece.
Google up rectifiers (envelope detector)
maybe a  Peak detector.
edit.
oops I forgot this. So we can see what we're working with.
http://3.bp.blogspot.com/-bEMBMvJwA5Y/TwrbbnpmzoI/AAAAAAAAAbw/EQ70PKQOFes/s1600/seaUrchin_Schematic.gif
