Boss CS-2 powersupply limiter
Started by manson, February 11, 2009, 09:47:51 AM
manson
I'm using an old Boss CS-2 compressor. It's supposed to reveive 12 volts through the old ACA type adapter. I'm using a regular 9v power supply. It works, but it doesn't get full power because of some limiter inside. I want to get rid of that, to make the pedal work as it should.
Am I right that removing R38 (470r) and D2, and putting a jumper in place will do the trick?
CS-2 schematic:
http://www.godiksennet.com/images/sch/CS2PG2.jpg
ayayay!
The people who work for a living are now outnumbered by those who vote for a living.
manson
Thanks, just modded it and it works perfectly!
