Did I get a good deal?
Started by whomeno, October 07, 2018, 08:57:59 PM
whomeno
#20
yes it is a 34, i just seen it also
I can't get a line on it at all.
pulled it apart checked the tubes all good but 1 a 1v2, would this tube keep it from showing a line. and of course I did not get on with all the tubes i got
Here is the schmatic for it
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
Quotewould this tube keep it from showing a line. and of course I did not get on with all the tubes i got
It won't work without that.     That provides the high voltage which accelerates the electrons towards the screen.  When the electrons hit the phosphorus screen green light is emitted.
Watch out around there it's probably about 1.2kV (1200V).
It is possible to replace that with a high voltage silicon diode(s) and maybe a series resistor.
I'm sure there's a web-page about it.
Here,
http://antiqueradios.com/forums/viewtopic.php?t=253609
They have some comments about replacing it with diodes.
whomeno
ordered a 1v2. will try again when I get it.will let everyone know how it gose
Gear as of now
And a lot of pedals
