Can you make a TS-9 automatically on ?
Started by Nuts, October 17, 2018, 05:01:21 PM
J0K3RX
Read section 2.1... whatever the current value is in your TS9 you will want to replace that resistor with one of a lower value.. For example: If it's 56k use a value between 40k and 50k..
https://cdn.shopify.com/s/files/1/1353/1185/files/clicklesstruebypasscatalog.allsections.interactive.2013-1.pdf?8064641489218286042
Nuts
YES !!!  :D it worked ! I had to change the resistor value, not the capacitor.
Thanks everyone ! :)
cctsim
#22
Try to change R127 from 56k to 68k or 82k.
