Andromeda Pots....
Started by BGaskamp, November 19, 2018, 01:55:09 PM
BGaskamp
Gonna give the Aion Andromeda build a go, but while ordering parts, the documentation gives you links to order parts, but when you get to the pots, it says select the correct one.
The two I am having an issue with is 50kC and the 25kB. I have the other two pots selected but don't know which ones these two are. Are they linear and reversed?
Wish it was just a hair clearer.
mth5044
They are in their abbreviated form in the build doc, but not on small bear. I can definitely see where you confusion is coming from! It hasn't always been the case, but the community at large seems to be gravitating to A = audio/log, B = linear, C = reverse audio/reverse log.
Hanzo
Quote from: mth5044 on November 19, 2018, 02:54:57 PM
Can confirm.  My Andromeda came out great following this convention.
also note - a 20k pot, sometimes even 22k, is same enough as a 25k pot, and a 47k pot is same enough for 50k. you are more likely to see 25k and 47k in the same manufacturers range.
also, welcome to the forum.
" I will say no more "
