Analog tap tempo for PT2399
Started by earthtonesaudio, September 28, 2011, 04:53:42 PM
earthtonesaudio
That would be cool.  Even better would be to share it here so others can benefit!  Best of luck!
GodSaveMetal
Quote from: jotajota0003 on March 14, 2015, 01:45:45 AM
well, I designed and assembled this your idea, actually I swept the entire internet looking for a tap that worked. But this his idea after some modifications, it worked! I am using this on my delay pedal.
reviving the post, in the schem there are no resistor to pin 6 in the delay; in the layout there are a 10K resistor R11 to pin 6 to the delay, is correct it??
Deilson
Has anyone done this project? I did but it did not work.
