Jfet buffer/splitter cap value
Started by vacuumdust, April 03, 2019, 05:23:40 PM
vacuumdust
In most simple jfet buffer schematics the output comes off the source through an electrolytic cap...generally 1uf to 10uf. I'm looking to build a signal splitter using one of these buffer schematics but I only have 47uf caps on hand. Lots of explanations of this little circuit but not much mention of that Output cap and how essential it is that the value is 1 or 10uf. Here's the schematic I plan to follow ..this one has 1uf. Can anyone help me understand the reasoning behind choosing the value for this cap. Thanks!
Bigger is better (within reason).
47u will suck-up crap on long lines better than a smaller cap.
Usually 10u or even 1u is "good enough", a penny cheaper, a mm smaller.
My garage loft needed a 4x4 post support. Foo, I used a 12" tree-trunk. The tree was handy, I'd have to go out to get a little 4-inch stick. The extra heft, and rounded (kind to car doors) shape, are bonus, like the super-low impedance of a 47u is your bonus.
vacuumdust
That's great!  Thanks so much for your explanation.
with all respect due to PRR, the output cap can be too big. at 47uF, it might cause blocking or gulp distortion. if so, you know you need a lower value. if it is a supply bypass cap, then Paul's comments do apply.
" I will say no more "
antonis
Output cap (as well as Input cap) mission, other than blocking DC, is to form a HPF with any impedance coming right after it..
If we don't know (or can't estimate) following impedance, oversizing is one-way solution..
(although, IMHO, 1μF should be adequate unless next effect exibits an input impedance lower than 10k..)
Depends.
Blocking requires a non-linear load. Load has not been specified. If an input is non-linear, it probably should take charge of its own blocking, not depend on the source having a quick recovery (low-C).
A smaller cap won't eliminate the blocking. Only shorten the "gulp" period.
But yeah, in guitar-boxes you do find some funny interactions.
