What can i do with fake J201 and 2N5457's?
Started by abakuzam, December 18, 2018, 08:24:34 AM
pinkjimiphoton
hook 'em up to your breadboard with a variac, and juice 'em as a sacrifice til the magick smoke goes out to the mojo gods.
Slava Ukraini!
~Jack Darr
I have recently bought few MMBFJ201 JFETs, Idss is around 0.4mA, Vgs(off) is around 0.3V (lowest part of specs), measured with GM328A transistor tester (which gives slightly lower values than ROG measurement method). Any ideas what to do with them?
edvard
Even the most out-of-spec JFETs can make wonderful buffers. Wire them up as a source-follower and put front-and-center as a high-impedance front end, driving a tone stack, following a high output-impedance gainstage, or at the tail end driving a 10K volume pot. Basically anywhere you'd normally put an op-amp non-inverting buffer and gain wasn't a primary concern.
