Boss DS1 mod for more volume, WITHOUT changing clipping diodes ?
Started by Xavier, July 11, 2019, 07:53:31 AM
Xavier
I am re-re-modding one of my Boss DS1's , and one of the things I did was to put back the back to back 1N4140 diodes...I really like it like this rather than with LED's
However, this means it again has the "barely less than unity gain" issue, where the pedal engaged sounds a bit quieter than disengaged.
I am looking at the output buffer here
I am wondering if the output buffer can be turned into a booster. By following an older post from user BAARON , I already changed R22 to 100R, C14 to 10mF and R23 to 10K, but no noticeable change in volume.
I was also wondering if a gain recovery stage with fixed gain (say 2 dB) could be inserted between Tone 2 and Level 3, before the switching, and what should that be ? Somehow I believe it would have to be integrated into the circuit, as part of it
Do you have any idea how this could be achieved ? Thanks !!
stonerbox
I would recommend you to read up on voltage dividers (R22 and R23). The changes you have done (100+10k) renders the exact same result as the 1k+100k.
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
merlinb
In an ideal world you would put the clipping opamp right after the first booster stage, then use the second opamp to add a little gain instead of being a useless buffer stage, but I guess you can't do this in an actual Boss build.
Steben
Quick question: do you prefer si diodes because of the higher amount of distortion?
Xavier
Quote from: merlinb on July 11, 2019, 08:52:35 AM
That's the key......converting this buffer stage into a booster stage, but I do not know if that would be possible....
merlinb
Quote from: Xavier on July 11, 2019, 09:31:42 AM
Perhaps you could remove the opamp and replace it with an IC socket. Then make a little board that plugs into the socket, with the reconfigured opamp and extra gain components suitably fitted to this little board?
Steben
Quote from: merlinb on July 11, 2019, 10:18:00 AM
Not really, the diodes will still clip to the same headroom.
Why not adding extra low knee voltage diodes like Schottky's and raising the gain of the opamp stage a bit? This will add some level while retaining most of the character.
Another option is changing the BJT with a P channel JFET.
mimmotronics
What you have is a common-collector BJT configuration for the output buffer:
https://www.electronics-tutorials.ws/amplifier/common-collector-amplifier.html
Looking at the diagram, it seems like the most relevant thing to do is convert the Common-Collector configuration into a Common-Emitter configuration, which introduces the ability to add some gain to the signal:
https://www.electronics-tutorials.ws/amplifier/amp_2.html
I can't run the numbers this moment, but this would be the path I would start walking down first.
merlinb
Quote from: Steben on July 11, 2019, 01:33:43 PM
The gain stage would be moved *after* the clipping stage, as I explained:
QuoteIn an ideal world you would put the clipping opamp right after the first booster stage, then use the second opamp to add a little gain
Lower-knee diodes will *reduce* the level.
Steben
Quote from: merlinb on July 11, 2019, 02:07:44 PM
Not if the gain stage is moved *after* the clipping stage, as I explained.
If one moves the gain stage after the clipping, the character changes entirely and you get lower diode clipping distortion. On top of that, you have a huge complex job in front of you.
Adding diodes in series is raising the total knee voltage.
Steben
Quote from: mimmotronics on July 11, 2019, 01:54:07 PM
PNP tranny to the rescue! You need to add a resistor to control the subtle gain.
merlinb
Quote from: Steben on July 11, 2019, 02:13:06 PM
That opamp is currently a unity-gain buffer that serves no purpose. I'm saying he could put it between the clipping stage and the tone stack instead (and give it a little gain), which will result in no change in clipping and no noticeable affect on character.
Ah makes sense now.
merlinb
Quote from: Steben on July 11, 2019, 02:18:00 PM
But isn't the OP modding a genuine Boss DS-1? In which case modifying that transistor will affect both the effect and the bypass signal equally. Maybe I misinterpreted the OP though.
Steben
Quote from: merlinb on July 11, 2019, 02:26:00 PM
True, but it is the OP which mentioned the output buffer.
I would settle for adding schottky diodes to the silicon ones and adding gain to the gain stage.
mimmotronics
Quote from: Steben on July 11, 2019, 02:29:27 PM
What model Schottky's are the standard? For Si diodes I'm familiar with 1N4148's and 1N400x's, but what are the Schottky equivalents?
Steben
Quote from: mimmotronics on July 11, 2019, 02:42:43 PM
BAT85
As drawn, since the bias is V/2, it won't bias usefully except at gain less than unity.
mimmotronics
Quote from: PRR on July 11, 2019, 11:08:15 PM
I don't see the need to sub in a PNP, my first approach would be to keep the NPN but put a resistor between +9V and the collector. Care to explain?
The trick to this approach is finding a way to modify the signal bias, and then balance that with the gain resistance so the volume can be brought up enough to where you want it... that sounds like a lot to go through though.
The schottky approach is much simpler to tackle first.
Steben
Quote from: mimmotronics on July 12, 2019, 08:47:42 AM
you wont get much gain if the signal comes from the emitter.
yes it is
