Plain vanilla test harness
Started by rockola, July 05, 2019, 05:40:02 AM
rockola
Frustrated by the growing pile of not-quite-right projects, I finally built a test harness. Also the perfect excuse to have some ice cream. There's breadboard space for up to 4 pots and any possible resistors/capacitors/etc. attached directly to them. Wires coming from the circuit are connected via speaker terminals.
The all-important gut shot.
The test harness on its maiden voyage, testing Matt Gray's BizNiz: http://graybloomfield.com/guitar/pedals/bizniz/
There's something not quite right with this build of mine (what a surprise), the gain pot seems to work as just another volume pot (didn't have a C10k so chucked in an A10k backwards), and I can't get it to distort. Anyway, the test harness seems to work, signal is going in and coming out, and the pots do something. Well, they started doing something once I remembered to populate the transistor & diode sockets (not the first time I've done this and most certainly not the last time either).
I knew from the start that the ice cream tub would be too flimsy for prolonged use. This is just a prototype for figuring out what the all-new improved version should be like. I already know there should be a bypass switch, it's hard to judge whether a boost is doing anything if there is no way to bypass the circuit.
When you make your improved version, you should label it "URBON VANIL" as a tribute to this one.
A test rig is something I still need to make myself.  I have a handful of enclosures from past endeavors that I should put to use on at least a basic rig.
Nice work!
antonis
#2
>didn't have a C10k so chucked in an A10k backwards<
That doesn't turn a Log pot pot into a anti-Log one..  :icon_wink:
Anyway, distortion (due to high gain) in such a circuit is a bit complicated..
It depends on Collector/Emitter resistor ratio but also on Feedback resistor/Input impedance ratio togheter with Feedback/Collector resistor ratio..
(1st & 3rd of them are quite satisfactory here..)
Which type of BJT have you used..??
rockola
Quote from: antonis on July 05, 2019, 06:12:00 AM
No. Wasn't too worried about the taper in this test. Backwards because it wouldn't fit otherwise...
2N3904 and 2N5089, with similar results.
reading this:
QuoteAlso the perfect excuse to have some ice cream.
had me worried about this:
QuoteThe all-important gut shot.
not sure your pots will withstand multiple insertions into the breadboard [or the breadboard from the pot pins battering], but if you only insert [once] the ones you intend to build with, probably won't damage the pin rivets.
too cold for ice cream here.
" I will say no more "
rockola
Got the BizNiz working. There may have been something else going on at first, but when I finally figured out that a gremlin had swapped IN and OUT on the test rig while I wasn't looking, everything was hunky dory.  :icon_redface:
Quote from: duck_arse on July 05, 2019, 10:53:29 AM
Good point. Not sure how to get around this easily.
I think you'll find that midwinter Down Under is not entirely unlike midsummer in Helsinki...
Quote from: rockola on July 05, 2019, 02:34:26 PM
Use 9mm pots with little pins? The vertical ones are good to use in breadboards if you break off the snap-in tabs that are supposed to hold them into a PCB.
GGBB
Technically no, but it can turn a log control into and anti-log one. Connected backwards (swap pins 1 and 3) and used backwards (counter-clockwise rotation for fuzz increase) will accomplish the same end.
Fancy Lime
It doesn't? Assuming by "anti-log" you mean "reverse logarithmic" , the C-taper pots I have do exactly what the A-taper ones do, but in reverse (allowing for the high tolerances that plague most pots). What resistance-vs-travel functions should A-taper and C-taper pots follow? Assuming this is half-decently standardized at all...
Cheers,
Andy
one way to beat the pins pounding is to twist the skinny lug-end bits 90o so the slip between the BB grippers. other way is to solder the pot to header pins, w/ the ones between pulled.
GGBB
#10
Quote from: Fancy Lime on July 06, 2019, 05:41:31 AM
Cheers,
Andy
You are correct. Practically speaking it works as desired (see my post above). But technically speaking the "pot" doesn't change its taper when you wire it backwards - it's still either a log pot or a reverse log pot. The "control" changes from being clockwise reverse logarithmic (with a "C" taper) to being counter-clockwise reverse-logarithmic (with an "A" taper) by substituting the pot and wiring and operating it backwards.
For the purposes of this discussion, the point you quoted is moot - we all know what we mean here.
Fancy Lime
Quote from: GGBB on July 06, 2019, 01:33:46 PM
Cheers,
Andy
For the purposes of this discussion, the quoted point is moot - we all know what we mean here.
'swhat I thought, thanks for the clarification, Gord. I somehow missed your previous post. Sorry bout that.
Andy
