Did somebody try this gigantic enclosure?
Started by Elijah-Baley, October 26, 2019, 06:46:53 AM
Elijah-Baley
This Hammond 500-0950 could be a really good enclosure.
http://www.hammondmfg.com/pdf/500-0950.pdf
The back is steel, and the top is aluminum, but the datasheet says «Top Panel is Made of 0.064" [1,62mm] Aluminum». It's even thinner than the ATPH enclosure I found early. ???
