MXR Blue Box fourth transistor Q4 name?
Started by Benoitcarp, November 28, 2019, 05:47:47 AM
Benoitcarp
Hi,
I have here a broken MXR blue bow with green pcb. Trasistor  (or regulator?) Q4 is broken and I can't seen what is written on it. Could anybody help me? This part doesn't show on classic blue box schematics...
Thank you fellars!
As far as I know, there are only 3 transistors in the circuit.
Is it possible someone decided to add a 4th one for some sort of buffering purpose?
antonis
If it IS that particular circuit, then the 4th transistor s apparently assigned to an added booster stage, in which case it can likely be any old NPN, assuming it conforms to the pinout.
