Volume control for Oscillating filter
Started by John Lyons, December 10, 2019, 06:06:31 PM
John Lyons
How can I adjust the volume of this circuit?
(I know that I can add series resistance to the
output but that doesn't give much attenuation
and cuts high end at high resistances.)
If I add a typical voltage divider volume control
the circuit will oscillate freely.
Basic Audio Pedals
www.basicaudio.net/
tubegeek
What happens if you put the divider in the middle - replace the 47K on Q1 a 50K pot and take the .1 from the wiper? Same problem or would that work better?
antonis
#2
My bad.. :icon_redface:
(didn't realize your issue)
John Lyons
#3
Quote from: tubegeek on December 11, 2019, 12:01:13 AM
It doesn't have any affect actually. (Strange).
When the wiper is at 9v it cuts out but nothing otherwise.
Thanks for the idea though.
Thinking of adding a buffer/gain stage and then a divider.
Basic Audio Pedals
www.basicaudio.net/
tubegeek
Quote from: John Lyons on December 11, 2019, 10:27:36 AM(Strange).
Huh. I wish it had worked! Best of luck going forward, onward and upward.
