What to do with those JFETs?
Started by rankot, January 30, 2020, 04:18:50 AM
Recently bought 100 MMBF5457 JFETs from Aliexpress. Measured them with transistor tester and they are all in range of 0.10-0.15mA for Idss and for -0.1V for Vgs(off). Any suggestions what to do with them? ROG JFET calculator says they can reach some 48 times of amplification, but for small signals only, since they will clip if input is bigger than 0.1V, if I understood that topic well. http://www.runoffgroove.com/fetzervalve.html
merlinb
Quote from: rankot on January 30, 2020, 04:18:50 AM
You are not measuring what you think you are measuring. That's not Vgs(off) or Idss, it's just a gate test voltage used by your analyser, and the resulting drain current.
The true figures for those JFETs will be larger. You can measure them with a multimeter and a 9V battery.
Looks like they should be good for most pedal JFET applications and are not too different from the popular J201 (maybe a little more selection needed).
antonis
You've understood it well enough but your measurements are not right - as Merlin already told you..
More gain realistic values should be 15-20 (marginally up)..
Still, it is likely Idss is under 0.25mA. (so not a 5457 spec.) Vto is harder to guess.
But I thought these little testers *would* swing to near zero both ways and display more-right Idss and Vto numbers? I don't see that here.
Quote from: merlinb on January 30, 2020, 04:53:44 AM
Merlin, I have compared measurements with ROG method (I have a dedicated PCB for that) and those with GM328A and they are NOT very similar for TO-92 JFETs. I simply don't have a way to measure those little fellows that way. But, for the sake of science, I will solder legs to one of them and measure with ROG method and see what happens. When I have measured 2SK117GR with GM328A, it shown 0.41mA for Idss and 0.33V for Vgs(off), while ROG measurement PCB shown 4mA and 0.62V. Quite different!
OK, I have just done it. Results:
GM328A: 0.16mA 0.1V
ROG: 1.1mA 0.36V
Still very low Vgs(off) (out of specs), and Idss is near the low end.
:P
QuoteWhen I have measured 2SK117GR with GM328A, it shown 0.41mA for Idss and 0.33V for Vgs(off), while ROG measurement PCB shown 4mA and 0.62V. Quite different!
GM328A: 0.16mA 0.1V
ROG: 1.1mA 0.36V
From what I can see the GM328A does not produce VP ad IDSS.
The V and I  measurements are just one point *somewhere* on the JFET's characteristic.   From the manual it speaks of a 680 ohm source resisistor.  To me that means it puts a 680 test resistor from the source to ground and connects the gate to ground and just measures the voltage across the 680ohm (and maybe the current down the JFET).  So if you calculate the V/I ratio of the numbers it produces,
    2SJ117GR:  Vmeasured / Imeasured  =  0.33V / 0.41mA = 805 ohm
    Dodgy MMBF5457= Vmeasured / Imeasured  = 0.1V/ 0.16mA = 625 ohm
and it's sure looks like the set-up implied by the manual with a 680 ohm resistor.
In the past you have posted IDSS and VP measurements from your ROG jig and they have looked OK.
At least you know what the ROG jig is doing.  The GM328A is just a black box.
Your MMBF5457's do look out of spec.  If you calculate r_min  = VP/(2*IDSS) using your ROG measurements you end-up with 163 ohms which is in the ball-park for that type of JFET.  So really they are just out of spec.   In the last few years we have seen a lot of low VP JFETs.
OK, now I have all the data - they are all very similar and all in this 1.0-1.1mA and 0.3-0.4V range. What to do with them?
merlinb
#8
Quote from: rankot on January 31, 2020, 04:44:33 AM
Small Vp is usually a good thing for pedal builders. Use them like any J201, or use them for analog switching.
antonis
According to ROG optimal biasing, you can use them as high-input-impedance(1M)-medium-gain(11-15) amps..
(e.g. followed by another identical stage amp for a distortion circuit of about 41 - 47 dB gain.. )
Thanks guys!
I suppose I can't use them for a phaser?  :-\
QuoteI suppose I can't use them for a phaser?
Not ideal but I did manage to help someone get a phase 90 with low VP's working quite well a few months back.
The trick was to divide down the signal to the gate so the LFO swing wasn't too large.  Didn't notice any distortion on a guitar but quite possible it would show up on a keyboard.
merlinb
#12
Quote from: rankot on January 31, 2020, 05:15:51 AM
Yes you can, you can use them for anything. (If you do build a phaser, try to pick out the JFETs that have matched Vgs(off), and the highest Idss. The Idss does not need to be matched though.)
