Pinout for Russian P416B Ge "Flat Hat" Transistor?
Started by matthew.wj, March 11, 2020, 05:25:24 PM
matthew.wj
I've searched around online to find the pinout for this peculiar transistor.
Seems like it is a bit different from other Ge transistors (and the Mill-Max socket it will be inserted into.)
The socket is CBE, but I *think* the transistor is ECB, with the collector in the middle. Can anyone confirm that?
I found a small dot on the rim of the hat. Someone somewhere posted a diagram in Russian. I don't read Russian, but using Google Translate, I think the small dot is the emitter, the middle is the collector, and the third is the base.
I'd love it if someone could confirm!
Bunkey
...just riffing.
j_flanders
#2
By coincidence I tried those in a Fuzz Face today. :)
I found various pinouts but since my transistors also have the dot on the rim I went with the same pinout as Bunkey posted.
https://alltransistors.com/pdfdatasheet_russia/p416a_p416b.pdf
The diagram on diy-tubes seems incorrect or coming from another transistor or there actually are different versions.
http://diy-tubes.com/index.php?route=product/product&product_id=651
matthew.wj
Did the ECB pinout arrangement work for your Fuzz Face?
j_flanders
Quote from: matthew.wj on March 11, 2020, 10:09:06 PM
Yes, that was the one, it worked.
