Salvaging Visual Sounds Route 66
Started by Bdrussell, March 12, 2020, 08:47:57 AM
Bdrussell
So I've got an older route  66 that had a bad tone pot functioned fine other than the shaft moved and would not always make connections. So I replaced it but in the process the circuit board traces started falling apart. The issue I'm running into is every time i try to repair a trace it just breaks in another place. I like the pedal alot and would like to salvage it. Is there a better way to do this or would it be easier to just start over and do everything point to point?
welcome to the forum, Bdrussell.
if you show us some photos of the problems, we [someone] will tell all you need to know.
are you feeling queezy yet? it's a good time to sell!
Bdrussell
This is the only picture I have right now. The pot I got had shorter terminals than the other but it was the only w20k pot I could find. Everytime I try to repair the traces they keep breaking.
antonis
Judging from traces condition, it shouldn't happen..
Try to use small lenght wire to connect pot lugs & respective traces away from lugs pads..
GibsonGM
Also be careful not to use too much heat!  You can scrape away the green insulation with an Xacto knife or something to expose the copper, and use a small wire like Antonis said, but be cautious.
