My first transistor overdrive / distortion
Started by Banjan73, April 23, 2020, 03:12:16 AM
antonis
Quote from: duck_arse on May 04, 2020, 10:56:46 AM
antonis - your Q3 bias might go a bit off without the decouple cap.
:icon_eek: :icon_eek: :icon_eek:
That $#@# happens when modyfing other people's schematics.. :icon_redface:
@Banjan73: In case of use Q3 buffer, place a cap on its wiper..
(or on Volume pot lug 1, which I smell it's Stephen's preference..) :icon_wink:
Banjan73
antonis
Banjan73
Hi.
I have now fine tuned the circuit. New now is the use of a capacitor to earth from emitter on Q2 also.
The circuit is tested with sound and scope from breadboard, and I think it`s working quite well. Lots of distortion and volume control is perfect. Nice square waves. I finally understood the meaning of the caps in paralell with the emitter resistor ;-)
Here`s hopefully the last version (if I don`t tweak it even more). 6.8uF is "enough" to square up the Q2 sufficient. Some components are already ordered (pots and caps):
antonis
Banjan73
diffeq
#66
Quote from: antonis on May 06, 2020, 09:32:51 AM
To good to be true...  :-[
Agreed - gain pot lug numbers are backwards. First pin should go to ground?
Banjan73
Well. The numbers aren't that critical. When I solder the pots, I will off course check that gain/volume increases with clockwise movement..
