As long as we’re doing old school: Gus Face
Started by soggybag, May 21, 2020, 03:04:24 PM
soggybag
antonis
vortex
Gus is the Rodney Dangerfield of stompbox design.
I can't figure out why, it just isn't right!
soggybag
That first board had a couple issues, all in the design, hopefully I've taken care of them in this version. While I had the mill set up I used the rest of the board to mill a Vulcan and a Smash Drive.
Hopefully these will work I'm still learning Eagle and the process of manufacturing boards on the mill. The Fuzz Face and the Vulcan use a ground plane. The smash drive uses a ground trace. I notice the mill treats these differently. With the ground plane it relies on the 1/64" bit, which looks pretty fragile. With a ground trace it does more work with the sturdier 1/32" bit. The ground trace was harder to layout.
